Strange Behavior of A Mesh Run at Two Dfferent Velocities Using Turbulence Model
Old   May 11, 2011, 15:22
Default Strange Behavior of A Mesh Run at Two Dfferent Velocities Using Turbulence Model
Zach
zachnap is on a distinguished road
Hello:
I made a fully-structured mesh of a generic projectile with a wall-spacing calculated from this site = 1e-6 m. I ran the mesh in Fluent with a kw-SST turbulence model with 1% turbulence intensity and 1 viscosity ratio at 100 m/s... my results were acceptable, qualitatively speaking; quantitatively off but... within reason. I ran the same mesh at 30 m/s, same settings, etc. and I get strange results - completely off in every respect... well, for half the length of the projectile. the first half of the projectile looks reasonable (and physical), yet the second half is completely separated flow which I know should not be there since we have PIV to use as a validation tool and is just nonsense anyway.
Is there anything that I should be accounting for when using a turbulence model and transition to siginificantly different velocities that could be causing this result? The mesh works well for Laminar runs at both 100 and 30 m/s.
I cannot include pictures...
zachnap is offline   Reply With Quote
Thread Tools
Trackbacks are On
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 6 October 7, 2015 13:54
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 17:15
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
