stream function boundary condition for cylinder with slots on it |
May 13, 2011, 08:47 |
sara
Hi.
I have written a code for flow field around a square cylinder. The base of my code is written in vorticity stream function approach. For calculation of stream function on the cylinder I have used "single pressure magnitude" for multi-connected domains. now it works properly. but after I decided to insert two slot on the top and down edge of square it dose not work any more. the down slot sucks the fluid and the upper slot blow the fluid by constant velocity. I was wondering is there any one who know how i can determine the right magnitude of stream function on the cylinder? thanks Last edited by sara2115; May 13, 2011 at 09:51. |
May 18, 2011, 09:50 |
Jonas T. Holdeman, Jr.
Rep Power: 18 |
See if I understand your problem. You have a 2D box with two symmetrically placed slots in the downstream face. The velocity is high enough that the box is shedding vortices. If shedding vortices, you would expect pressure near the slots to oscillate, the two slots more or less out of phase. Similarly, you would expect out-of-phase flow in and out of the slots.
If this is correct, then you would expect the value of the stream function on the surface between the slots to oscillate. This value would not be fixed by a static boundary condition, but rather would have to be determined as a part of the calculation. |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
