propane burning rate
does anybody know which is the propane burning rate? Or in which handbook can be found? It seems..i cannt find it. Thank you |
Re: propane burning rate
What is the equivalence ratio ?
Hmm dont know...I need this beacuse i want to calulate the heat release over a surface
Can you define your problem properly
Propane is burning on a surface of 0.61m*1.21m in a room of 3*5*5. I want to find out which is the heat release rate for this fire. If i know the burning rate i can define this as a mass flow rate at the inlet
didi |
Alcanes have a heating value between 45-50 e6 J/kg.
The burning rate depends on the configuration: in a diffusion flame, it is a function of the strain, in a premixed flame, it varies with the equivalence ratio and stretch. |
