March 11, 2005, 16:02 |
exact solution to axi stokes pipe found?
Hi, is the exact solution to axisymmetric stokes flows (steady and incompressible) in pipe found?
if yes, what's it, or where to find it? thanks a lot |
March 14, 2005, 05:15 |
Re: exact solution to axi stokes pipe found?
In any text book on fluid mechanics - the solutions a parabola just as in the cartaesian channel case.
If you're feeling adventurous you can also write down the unsteady solution for this problem. |
March 14, 2005, 12:24 |
in non fully developed region
thanks a lot, but I meant the solution in non-fully developed region; suppose the inform inflow is uniform.
March 15, 2005, 05:06 |
Re: in non fully developed region
It depends on the boundary conditions and what you assume. For general boundary conditions the answer is NO since you'll need to solve the fully nonlinear equations analytically. If your inflow profile matches the fully devolped profile and you have Neumann conditions at the outlet then the anylitic solution is the fully developed solution everywhere.
Special cases with the Reynolds number (R) <<1 and >>1 are possible. You could also get somewhere with the case where the inflow differs from the fully developed profile by a small amout (or even mixtures of these three cases). |
Exact solution of Buckley_Leveret equation | mcaro | Main CFD Forum | 0 | January 25, 2011 06:52 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
