Mesh domain size independancy check
Old   May 23, 2011, 09:20
Question Mesh domain size independancy check
Kisorthman Vimalakanthan
k.vimalakanthan is on a distinguished road
Hi guys,
I was hoping someone could give me an answer to my problem. I'm trying to check for domain size independency, but do not have a valid way to go about addressing this problem. I am aware that for mesh refinement study number of authors have suggested the Richardson’s extrapolation method. However I have been told that Mesh domain size convergence is not carried out the same way.
Hence could someone please suggest the best way to compare three different size meshes? I.e. for an airfoil simulation, the extent of the domains varies as 10chord, 20chord and 40chord, keeping the number of nodes constant.
Thanks in advance.
Dept. of Power and Propulsion
Cranfield University
Email: k.vimalakanthan@gmail.com
k.vimalakanthan is offline   Reply With Quote
Old   May 23, 2011, 10:37
Praveen. C
praveen is on a distinguished road
You want to test dependance on domain size. Then you should not change the grid, but you should simply extend it. E.g., you do a computation with domain radius r1. Then extend domain size by adding more layers of mesh to reach a higher radius r2. Note that mesh within radius r1 does not change this way.
If you using structured grid, you could generate mesh with largest domain size. Then remove outer layers of mesh to get mesh for smaller domain size.
praveen is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
ICEM Tetra mesh, Size reduction and Skewness problem Catthan ANSYS Meshing & Geometry 6 December 5, 2010 19:39
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Gambit Unstructed (Tet) Mesh - size control newbie FLUENT 3 August 26, 2008 11:38
