Ic Heat spreader
Old   March 16, 2005, 21:22
Default Ic Heat spreader
Klaus Ong
there are some many shapes of heat spreaders available in the market such as "star" shape etc. This type of heat spreader is used to attach to IC's die. The question is: Why people made heat spreader with such a funny shape? And what's the main reason behind it? Thanks
Old   March 17, 2005, 09:25
Default Re: Ic Heat spreader
ag
The shapes are derived from the desire to maximize surface area relative to the volume of metal. Ideally you want the temperature at the surface of the heat sink to follow as closely as possible the temperature of the IC. Since a large volume of heatsink material would introduce a significant lag in the time response (look at the time-dependent conduction equation) then a small volume of material is desired. But in order to maximize convective heat transfer at the surface, surface area needs to be as large as possible. Thus you end up with heat sinks with lots of fins, pins, and whatever else can be reasonably manufactured.
Old   March 17, 2005, 22:21
Harry Fulmer
I don't think it's an issue of the transient behaviour of the heatsink that drives its design. The increase in surface area is key, heatsinks are simply 'area extenders'. By increasing the surface area you have to be careful that this positive effect is not compromised by the thermal resistance of the heatsink itself. Metrics such as the spreading resistance in the base (when the heat source area is smaller than the heatsink base area, fin efficiency and heatsink mass (for cost and mechanical concerns) should be considered.
www.coolingzone.com has lots of stuff about heatsinks, worth checking out.
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
how to impose experimental dat as boundary conditi Rogerio Fernandes Brito FLUENT 14 November 25, 2008 05:47
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
