Dielectrophoresis CFD-ACE+
Old   March 24, 2005, 12:25
Default Dielectrophoresis CFD-ACE+
Mahesh
Hi everybody,
I am using the spray+flow+electric modules in CFD-ACE GUI for simulating positive dielectrophoresis. I have the following observations and it would be great if someone could help me out with this.
1. For equal permittivity and conductivity of spray particle and medium there is no movement - WHICH IS CORRECT
2. For permittivity and conductivity of spray particle lower than that of the medium there is movement away from the higher field density region - WHICH IS ALSO CORRECT
3. For permittivity and conductivity of spray particle greater than that of the medium there is SLOW movement away from the higher field density region - WHICH IS NOT supposed to happen.
This basically means that there is only different extents of negative dielectrophoresis and no positive.
If anyone could suggest any solutions it would be of great help. Also if you need any more information let me know.
Thanks MK
about VOF. Fluent or CFD ACE? Jiyeon FLUENT 5 January 17, 2012 04:37
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 September 13, 2000 04:48
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
