May 19, 2011, 03:26 |
Convection heat transfer & rugosity
Rep Power: 16 |
I would like to know if rugosity can have a significant impact on the value of the heat transfer convection coefficient ? My system is a long pipe in which I have free convection (Ra > 10^9 and Re > 12 000). I am assuming a zero rugosity and I think this has no impact, what do you think? Answers with references would be good! Best regards, Koranten. |
May 24, 2011, 23:15 |
Oky Andytya
Rep Power: 15 |
Hi everyone,
I need help, how to get the value of convection coefficient [h] from Fluent directly? Thank you. Regrads, Oky |
May 25, 2011, 02:52 |
Rep Power: 16 |
You're not helping, but I can help you.
You just have to look a the definition of h, which is : heat flux = h * DT (W/mē) So : h = heat flux / DT With : heat flux = area weighted average of surface heat flux (be careful if you have radiation, you should not take it into account, by doing 'total surface heat flux - radiation heat flux') DT = T_wall - T_infinite T_wall = area weighted average of Wall Temperature T_inf = it is up to you! You should choose what is your reference temperature! |
May 25, 2011, 08:54 |
Andrew
Rep Power: 18 |
are you treating the rugosity as a change in the area or something like a friction factor for the pipe?..either way, I guess it could impact the convective coefficient if the value is large enough
May 25, 2011, 10:06 |
Rep Power: 16 |
I am using FLUENT. The rugosity is set to zero and I'm not sure this could have a real impact, and I cannot do any tests for the moment.
May 25, 2011, 10:12 |
Andrew
Rep Power: 18 |
my very limited experience with rugosity leans me to not thinking it would apply to pipe flow, but I could be wrong. I would leave it at zero. Or, you could step it up and see what happens to your results.
model forced convection heat transfer on a heat sink | farzad | FLUENT | 0 | September 9, 2010 14:48 |
Heat transfer, convection, radiation, conduction | Sandra H. | OpenFOAM | 1 | March 3, 2010 08:02 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
