matlab mesh generation for fluent
Old   May 26, 2009, 17:26
Default matlab mesh generation for fluent
Mike
mleahy is on a distinguished road
I have been working on a elliptical mesh generator for an airfoil in matlab. I want to be able to write the mesh in a format that can be read by fluent. are there any source codes available that can do this? or other recommendations?
mleahy is offline   Reply With Quote
Old   May 28, 2009, 22:19
N/A
harishg is on a distinguished road
I guess fluent can read vtk meshes. Check for the documentation which gives you the details of writing vtk meshes. Another option you can try if you have tecplot is to write the ascii data in tecplot format. Open it with tecplot and export it to fluent format.
harishg is offline   Reply With Quote
Old   May 29, 2009, 10:58
RenardP is on a distinguished road
Fluent is an unstructured solver and if I understand correctly you have implemented a structured grid generation method in Matlab. You need to write your mesh in format similar with this (for a 2D mesh):
n1 n2 n3 4
x1 y1
Where n1,n2 ... are the vertex numbers and x1 y1 are the coordinates of n1; x2 y2 the coordinates of n2 ....
In order to be able to import your mesh in Fluent I suggest you to create a simple 2D mesh example in Gambit (the mesh generator of Fluent) save this mesh in neutral format (*.neu). Using this file you will be able to see how you must format your mesh file in order to be able to use it with Fluent.
If you need help in coding this let me know.
RenardP is offline   Reply With Quote
Old   May 29, 2009, 11:43
Question that post lets me wonder about this
amira maizi
amira is on a distinguished road
can we write a UDF using matlab and implement it into Fluent?
amira is offline   Reply With Quote
Old   May 31, 2009, 19:17
First, I strongly recommend you to read the Fluent help about UDF.
About your question now, the answer is NO! You can write a UDF only in the C language.
Old   October 11, 2013, 07:50
Sorin Munteanu
Sorin is on a distinguished road
Hi Amira,
A Fluent UDF is a C library, so technically the answer is No.
You can drive Fluent from Matlab, though, but that is slightly different functionality that the one you handle in UDF. It is the equivalent if running Fluent in batch from a .m file instead of doing it from a *.jou file.
Sorin
Sorin is offline   Reply With Quote
fluent, matlab, mesh
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 15:20
ICEM - incomplete mesh generation ralph CFX 0 June 23, 2008 23:35
2D mesh generation!! HELP...! Jesper Sørensen Main CFD Forum 1 October 24, 2006 17:58
need info on companies in mesh generation Ramesh Main CFD Forum 1 June 24, 2006 09:15
Mesh Mignard FLUENT 2 March 22, 2000 05:12
