March 2, 2005, 05:33 |
[Question]CFD-Fastran Chimera+Moving
I faced a case that simulate aircraft drop bomb,I have created grids with IcemCFD,and use it merg the aircaft grid and the bomb grid to be chimera grid...After i imported it into CFD-Fatran.I found there are more than 1000 zones in the structure grid.And i couldn't use Shift and Ctrl key to define the overlaps zones.the work is so huge.........Who can tell me if there has a good way to do this.......thank you very much
March 3, 2005, 04:07 |
Re: [Question]CFD-Fastran Chimera+Moving
I would suggest using CFDRC's own mesh generator Geom, rather than ICEM. I have experience of both, and I definitely prefer Geom. Geom is particularly good at merging the mesh blocks, which makes life a lot simpler.
March 3, 2005, 07:41 |
I have used geom, but not good,I could only make 2D mesh with GEOM.Could you teach me about GEOM?????,I thibk it will take a long time for me to make a grid of a aircraft and bomb......I want to kown,could grids from ICEMCFD be merged in GEOM???first i change it into *.DTF,and then open the *.DTF in GEOM,I have tried, Geom could merg some of the zones....but i don't kown if the grids after merged useful.....Did you have any experience of this??????Thank you very much...
March 30, 2005, 00:50 |
anyone find that with the new version of fastran the species are not appearing for in the species list in the properties submenus? i also find that if i load say lotemp.dat then it doesn't read it properly and half the species are actually things like 1.17707D01.... I never had this problem with the older version anyone else have the same problem?
HELP - Moving car simulation in fluent | Brad Wells | FLUENT | 7 | January 4, 2018 19:55 |
[snappyHexMesh] jagged, ragged edges... | ziemowitzima | OpenFOAM Meshing & Mesh Conversion | 138 | July 23, 2012 23:41 |
Moving mesh in Fluent | fivos | FLUENT | 0 | April 2, 2010 09:45 |
Overset (Chimera) for moving bodies? | Alan | Main CFD Forum | 6 | January 20, 2006 02:37 |
moving cylinder | blur boy | Main CFD Forum | 4 | October 12, 2001 05:32 |
