-   -   Nusselt number calculation (http://www.cfd-online.com/Forums/main/89614-nusselt-number-calculation.html)
vinaykumar June 17, 2011 09:25
sir i have to calculate the nusselt number ratio augumentation for dimple surface and smooth surface for reynolds number for laminar flow
Nu/Nuo..plz help me
morteza08 June 20, 2011 04:40
Hi
Did you find your answer.
I also worked on dimpled surface in fluent and gambit and now I am working on a code for simulating the convective heat transfer along a dimpled surface.
let me know if you need help yet
vinaykumar June 20, 2011 09:09
nusselt number
respected sir plz send me the formula for nusselt number augumentation for flat and dimpled surface by reynolds number are 500 750 1000 1650 respectively
and cf/cfo ratio.
morteza08 June 20, 2011 10:25
ftp://ftp.eng.auburn.edu/pub/hejingl...late/step6.htm
http://www.codecogs.com/code/enginee...sselt_flat.php
http://cfd.iut.ac.ir/files/plate.pdf
http://www.google.com/url?sa=t&sourc...G9m9t8xvjdSoyg
In all of thw above links there are formulas for calculating the nusselt number.... and how to calculate the nu number in fluent..
vinaykumar June 21, 2011 08:27
friction factor calulation
sir i want to calculate the friction factor for the reynolds number 500,750,1000,1650
for both the flat plate and dimpled surface.
thank u
morteza08 June 21, 2011 08:39
hi
this may help you
read carefully
https://confluence.cornell.edu/displ...t+Plate+step+6
