June 20, 2011, 10:42 |
Upwind, central, QUICK scheme for Re~10000
TWB
Rep Power: 19 |
I am trying to solve flow past an airfoil at Re~ 10,000. I am assuming laminar flow at the moment. What type of schemes should I choose? Like upwind, central, QUICK scheme etc? Is there a preferred scheme? Thanks! |
June 20, 2011, 15:13 |
Morteza
Rep Power: 15 |
Hi
May be this help you: Read the FLuent modelling part of the tutorial.... I think the default parameters going true for your case.. http://www.google.com/url?sa=t&sourc...ZRux4cY5wKhOdQ |
June 22, 2011, 12:18 |
TWB
Rep Power: 19 |
Hi Morteza, thanks for the suggestion!
However, after reading thru the fluent part, it seems to only mention that it's using the PRESTO scheme. Nothing else much. Did I miss out something? |
June 23, 2011, 08:52 |
anil
Rep Power: 14 |
Under Discretization, set Pressure to PRESTO, pressure velocity couling to SIMPLE and Momentum to Second-Order Upwind
June 23, 2011, 15:04 |
TWB
Rep Power: 19 |
Thanks akj! However, I am writing my numerical solver and I need to solve for relatively high Re (~10000) flow past an airfoil.
I wonder if anyone has experience and what type of schemes are more suitable for flow at this Re. |
2nd order upwind and QUICK scheme | Wiroon | Main CFD Forum | 19 | September 17, 2019 03:47 |
2nd order upwind vs 2nd order upwind!!! | Far | Main CFD Forum | 7 | March 14, 2013 12:29 |
Second order upwind is not UPwind!!! | Far | CFX | 9 | May 31, 2011 08:21 |
2nd order upwind scheme (Fluent and CFX) | Far | FLUENT | 0 | May 22, 2011 01:50 |
Definition of limiter function for central dirrerencing scheme | sebastian_vogl | OpenFOAM Running, Solving & CFD | 0 | January 5, 2009 11:08 |
