makefile
Old   April 26, 2005, 17:54
Default makefile
jojo
Hi everybody,
Has anyone worked with MPICH on Windows stations?
I am not used to Makefile on Windows and I do not understand where I can put the lines (as required in MPICH documentation):
-I C:/Program Files/MPICH/SDK.gcc/include -L C:/Program Files/MPICH/SDK.gcc/lib -lmpich
Make reports error when using those lines.
Thanks in advance,
Jojo
Old   April 27, 2005, 09:04
Default Re: makefile
ag
I can give you a few pointers. First, C:/Program Files/MPICH... is not a valid directory under windows because windows uses a \ as the directory separator, not the / that is used in Linux and Unix. Second, do those directories exist? You don't list the error you're receiving. Third, do you have MPICH set up on the windows machine to use gcc as the C-compiler?
Old   April 27, 2005, 09:27
jojo
Dear ag,
Thanks a lot for your quick answer.
The error is the same, whatever \ or / is used: "missing separator"
I have followed each step of the documentation but there is not much information in it.
Best Regards,
jojo
Old   April 27, 2005, 09:48
scicomex
In writing makefiles, the "TAB" and "end of line" are essential. These change if you save the file in PC (or WINDOWS) format or if you do it in UNIX format. You can check that by typing:
cat -evt myfile.something
If you see some "^M$", the file is in WINDOWS format. If not, you have it in UNIX. May be that's the problem.
Old   April 28, 2005, 09:25
jojo
Dear Scicomex,
Thanks a lot for your message.
I should not have any problem of that type since I have written the makefile on the PC (using Notepad). I think my real problem is related to the position in the makefile I have to put the lines related to MPICH: -I .../MPICH/.../include and -L .../MPICH/.../lib (i.e. the full path to the include and lib directories). When compiling in a "normal" way, the makefile works fine.
Thanks again,
jojo
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
Makefile for f90 under unix Jinwon Main CFD Forum 1 September 22, 2007 05:10
Making a solver a fully independant object dauptain OpenFOAM Installation 4 March 7, 2007 11:17
Need Makefile for GCC in windows to compile UDFs Filipe Madureira FLUENT 2 December 28, 2005 16:08
about making makefile JunseokKim Main CFD Forum 1 May 16, 2001 21:39
