-   -   Turbulence model for transsonic flow (http://www.cfd-online.com/Forums/main/9021-turbulence-model-transsonic-flow.html)
Wei April 13, 2005 11:16
I want to calculate a transsonic flow in a nozzle. Which turbulence model should I choice? Thanks.
buch April 14, 2005 04:46
Re: Turbulence model for transsonic flow
Hi Wei
Currently the trend is to use the Menter's BSL or SST model. It has a pretty good behaviour vs adverse pressure gradient, and is not sensitive to the far-field values contrary to the original Wilcox k-w.
If this model is not available in your code, you can try another model, the point is to take into account some realizability constraints, in practice to adopt a dynamic Cmu and not a constant one.
You may find some papers of Thivet for example on that argument.
Good luck !
