Lagrangean version of Actuator Discs
Old   July 6, 2011, 15:11
Default Lagrangean version of Actuator Discs
Cristian Paris
CristianParis is on a distinguished road
Hi everyone
I'm currently running simulations of wind fields using particle methods. I want to incorporate the interaction of my particles with a wind turbine, using an Actuator Disc; however, I'm not sure if the concept is applicable, since its deduction is purely Eulerian. Specifically, the following problem arises:
In the Actuator Disc theory, a wind turbine may be represented as a thrust force proportional to the square of the incoming velocity... But suppose a particle has a speed greater than one (in some unit system). Then it may very well happen that the particle "bounces back" at the generator, since the speed decrease induced by the thrust force might be greater in magnitude than the original incoming speed!
Is this an inconsistency of the Actuator Disc model in general? How might one solve it?
Thanks in advance!
CristianParis is offline   Reply With Quote
Thread Tools
Trackbacks are On
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
bubbleFoam validation case balkrishna OpenFOAM Running, Solving & CFD 24 August 30, 2010 04:37
version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found ovie Main CFD Forum 1 April 19, 2010 14:00
Problem with paraFoam on a linux-64 bit bunni OpenFOAM Paraview & paraFoam 4 April 14, 2010 20:55
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
