anyway to install 32 bit fortran on 64 bit machine
is there any way to install 32 bit fortran compiler in the 64 bit machine...
any ideas r welcome |
which compiler do you want to install?
Most 64 bit machines will run 32 bit code by design. I'd try the software and see if there are any errors. You are most likely to run into PIC errors if any at all if trying to run on the 64 bit machine.
gfortran/gcc has 64 bit fortran compiler
Which OS are you using ?:confused:
