regarding fortran compiler
Ok so i have the 64 bit machine with windows 7 on it.. i need to run fortran code in this.. the previous fortran compiler is not working on it as it is 32 bit....i tried to go in the x86 folder and tried to install the setupx86 file but it did not install...
Now i realy need to run the code and i dont have any experience on Unix commands so running the gfortran is also difficult for me... If anybody can give me step by step instructions to install the Gfortran , compile and run the code ill be very thankful as it seems to be the only solution and way out.... |
http://www.mingw.org/ |
Fortran for window, see here:http://www.equation.com/servlet/equation.cmd?fa=fortran
it is self-extracting executable, and run the executable to install,easy. ftp://ftp.equation.com/gcc/gcc-4.6.0-64.exe |
Fortran
Try evolution version of Fortran compiler . And "Ok so i have the 64 bit machine with windows 7 on it.. i need to run fortran code in this.. the previous fortran compiler is not working on it as it is 32 bit....i tried to go in the x86 folder and tried to install the setupx86 file but it did not install..." :confused: 64 bit should support 32 bit package :rolleyes: |
