Subroutine for Block tridiagonal System
Old   February 26, 2007, 21:39
Default Subroutine for Block tridiagonal System
Khan
I am looking for subroutine for solving block tridiagonal solver(periodic and non periodic). I found in the book of Anderson but some one in this forum suggest that it has an error, which i dont know.
Could any help me by sending the subroutine or help me in finding the error in the subroutine given in the book of anderson.
thanks
Old   February 27, 2007, 01:49
Default Re: Subroutine for Block tridiagonal System
UT CAA guy
Here is the routine out of the Tannehill book "Computational Fluid Mechanics and Heat Transfer"
This will be an exact copy, and it looks like fortran77
c..subroutine to solve non-period block tridiaganol c..system of equations without pivoting strategy c..with the dimension of the block matrices being c..n x n (n is any number greater than 1)
SUBROUTINE NBTRIP(A,B,C,D,IL,IU,ORDER) INTEGER ORDER,ORDSQ DIMENSION A(1),B(1),D(1)
C..A = SUB DIAG. MATRIX C..B = DIAG. MATRIX C..C = SUP DIAG. MATRIX C..D = RIGHT HAND SIDE OF VECTOR C..IL = LOWER VALUE OF INDEX FOR WHICH MATRICES ARE DEFINED C..IU = UPPER VALUE OF ' ' ' ' C.. (SOLUTION IS SOUGHT FOR BTRI(A,B,C)*X=D C.. FOR INDICES OF X BETWEEN IL AND IU (INCLUSIVE). C.. SOLUTION WRITTEN IN D VECTOR (ORIGINAL CONTENTS C.. ARE OVERWRITTEN)). C..ORDER = ORDER OF A,B,C MATRICES AND LENGTH OF D VECTOR C.. AT EACH POINT DENOTED BY INDEX I C.. C..THE MATRICES AND VECTORS ARE STORED IN SINGLE C..SUBSCRIPT FORM
ORDSQ = ORDER**2
C.. C.. FORWARD ELIMINATION C..
I=IL
IOMAT = 1+(I-1)*ORDSQ
IOVEC = 1+(I-2)*ORDER
CALL LUDECO(B(IOMAT),ORDER)
CALL LUSOLV(B(IOMAT),D(IOVEC),D(IOVEC),ORDER)
DO 100 J=1,ORDER
IOMATJ = IOMAT+(J-1)*ORDER
CALL LUSOLV(B(IOMAT),C(IOMAT),C(IOMATJ),ORDER) 100 CONTINUE 200 CONTINUE
I=I+1
IOVEC = 1+(I-1)*ORDER
I1MAT = IOMAT-ORDSQ
I1VEC = IOVEC-ORDER
CALL MULPUT(A(IOMAT),D(I1VEC),D(IOVEC),ORDER)
DO 300 J=1,ORDER
I1MATJ = I1MAT+(J-1)*ORDER
CALL MULPUT(A(IOMAT),C(I1MATJ),B(IOMATJ),ORDER) 300 CONTINUE
IF(I.EQ.IU) GOTO 500
DO 400 J=1,ORDER
CALL LUSOLV(B(IOMAT),C(IOMATJ),C(IOMATJ),ORDER) 400 CONTINUE
GOTO 200 500 CONTINUE
C.. C.. BACK SUBSTITUTION C..
I=IU 600 CONTINUE
I=I-1
IOMAT=1+(I-1)*ORDSQ
IOVEC=1+(I-1)*ORDER
I1VEC=IOVEC+ORDER
CALL MULPUT(C(IOMAT),D(I1VEC),D(IOVEC),ORDER)
IF(I.GT.IL) GOTO 600 C..
RETURN
END
C.. SUBROUTINE TO CALCULATE L-U DECOMPOSITION C.. OF A GIVEN MATRIX A AND STORE RESULT IN A
SUBROUTINE LUDECO(A,ORDER)
INTEGER ORDER
DIMENSION A(ORDER,1)
DO 8 JC=2,ORDER 8 A(1,JC) = A(1,JC)/A(1,1)
JRJC = 1 10 CONTINUE
JRJC = JRJC+1
JRJCM1 = JRJC-1
JRJCP1 = JRJC+1
DO 14 JR=JRJC,ORDER
SUM = A(JR,JRJC)
DO 12 JM=1,JRJCM1 12 SUM = SUM-A(JR,JM)*A(JM,JRJC) 14 A(JR,JRJC) = SUM
IF (JRJC.EQ.ORDER) RETURN
DO 18 JC=JRJCP1,ORDER
SUM = A(JRJC,JC)
DO 16 JM=1,JRJCM1 16 SUM = SUM-A(JRJC,JM)*A(JM,JC) 18 A(JRJC,JC) = SUM/A(JRJC,JRJC)
GOTO 10
END
C.. SUBROUTINE TO MULTIPLY A VECTOR B BY A MATRIX A C.. SUBTRACT RESULT FROM ANOTHER VECTOR C AND STORE C.. RESULT IN C. THUS VECTOR C IS OVERWRITTEN
SUBROUTINE MULPUT(A,B,C,ORDER)
INTEGER ORDER
DIMENSION A(1),B(1),C(1)
DO 200 JR=1,ORDER
SUM = 0.0
DO 100 JC=1,ORDER
IA = JR+(JC-1)*ORDER 100 SUM = SUM+A(IA)*B(JC) 200 C(JR) = C(JR)-SUM
RETURN
END
C.. SUBROUTINE TO SOLVE LINEAR ALGEBRAIC SYSTEM OF C.. EQUATION A*C=B AND STORE RESULTS IN VECTOR C C.. MATRIX A INPUT IN L-U DECOMPOSITION FORM
SUBROUTINE LUSOLV(A,B,C,ORDER)
INTEGER ORDER
DIMENSION A(ORDER,1),B(1),C(1)
C.. FIRST L(INV)*B
C(1) = C(1)/A(1,1)
DO 14 JR=2,ORDER
JRM1 = JR-1
SUM = B(JR)
DO 12 JM=1,JRM1 12 SUM = SUM-A(JR,JM)*C(JM) 14 C(JR) = SUM/A(JR,JR)
C.. NEXT U(INV) OF L(INV)*B
DO 18 JRJR=1,ORDER
JR = ORDER,JRJR+1
JRP1 = JR+1
SUM = C(JR)
DO 16 JMJM = JRP1,ORDER
JM = ORDER-JMJM+JRP1 16 SUM = SUM-A(JR,JM)*C(JM) 18 C(JR) = SUM
RETURN
END
I guess if I get really bored tomorrow, I'll post the periodic subroutine, which uses the same sub..subroutines.
Old   February 27, 2007, 01:50
UT CAA guy
wow, that posted really funky, i hope you can read it
Old   February 27, 2007, 02:16
khan
Hi! UT CAA
Thanks for positing the code. have you tested it or not??
in a previous message at this forum, there is a discussuion about this code, which says
" Both of subroutine ludeco and lusolv have the same error. It appears that the code has not been tested in the form as in the book before publication of the book."
but no one point out the exact error. Are you sure about it correctness ?
Khan
Old   February 27, 2007, 10:41
UT CAA guy
Oh, I wasn't sure that it was the same code as in the Anderson book...guess it makes sense that he's the second author.
I will give it a look, but you should have a general idea of the process, and the subroutines aren't 'that' long.
So, as and cfd person would, debug, debug, debug
Old   July 6, 2011, 03:44
vijay kadli
vijay kadli is on a distinguished road
hi frnd.. i am solving euler implicit equation and i went thru this btdma solver.. but cudn debug!! can u help me?
vijay kadli is offline   Reply With Quote
Old   July 8, 2011, 14:16
Docfreezzzz is on a distinguished road
I have source code up on the following site if you would like it.
Block Tridiagonal Solver
CFD engineering resource
Last edited by Docfreezzzz; July 22, 2011 at 15:37. Reason: Eliminate direct code paste
Docfreezzzz is offline   Reply With Quote
Old   July 11, 2011, 06:49
Default btdma
vijay kadli
thank u.. wil try the same logic with fortran
thanks once again
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
block tridiagonal system solver for periodic bc Abdullah Main CFD Forum 8 February 23, 2007 13:15
Tridiagonal System Zhong Lei Main CFD Forum 3 May 24, 2001 14:18
On the block tridiagonal linear system zhanglei Main CFD Forum 2 July 24, 2000 06:15
On the block tridiagonal linear system zhanglei Main CFD Forum 0 July 18, 2000 08:55
