effect of variable meshing
Dear All!
I am modeling flow in a channel under gravity. As compared to a uniform mesh ,in case of a variable mesh(very fine to coarse),I am getting quite different values of velocity of flow. anybody ,please suggest ? regards, |
Rakesh:
You don't say whether your uniform mesh was uniformly fine or uniformly coarse. If the latter, the solution was bad compared to the solution on the variable mesh. Just a thought. |
Mr. John,
Thank you very much for your good suggestion. regards, Rakesh |
