Engine manifold flow
Like Tree1Likes
  • 1 Post By stephen_devaux
Old   July 21, 2011, 02:40
Default Engine manifold flow
Stephen
stephen_devaux is on a distinguished road
Good day all
I'm a 4th year engineering student tasked with using CFD to analyze the effects of pressure pulses, scavenging, Helmholtz resonance and so on in the exhaust and inlet manifolds of a 4 stroke IC engine. I do not have a large amount of CFD experience and I was hoping some one could point me in the right direction with concerns to the following, Firstly 1-d vs 2-d vs 3-d, and secondly should one model the entire cylinder with valves including the combustion or would it be sufficient to use a user defined source with varying pressure/mass flow rate's at the inlet or exit of the manifolds?
Jenisha_Naidoo likes this.
stephen_devaux is offline   Reply With Quote
Old   July 21, 2011, 02:51
chocolate_rain is on a distinguished road
what cfd software are you using.
chocolate_rain is offline   Reply With Quote
Old   July 21, 2011, 02:54
Stephen
Hi chocolate_rain im using fluent, but i also have access to CFX. Im not aware of any advantages of either
engine, exhaust, inlet, pressure pulse
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Race Engine Air Flow john grudynski Main CFD Forum 0 May 21, 2006 01:50
internal combustion engine port flow simulation Nyquist Siemens 1 April 29, 2003 03:48
IC Engine Flow simulation Apurv Main CFD Forum 2 February 8, 2000 00:12
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
