A question of absorption coefficient units
Old   August 2, 2011, 04:17
Default A question of absorption coefficient units
ljwbuaa is on a distinguished road
Recently, I work on how to calculate the radiation by finite volume method.
In this method, an absorption coefficient is needed. I got the absorption coefficient from NASA-SP-3080.But the unit of absorbtion coeficient
is inverse centimeter(1/cm).My question is : if I want to use it in meter unit system, the unit of absorbtion coeficient (1/cm) should be change to inverse meter(1/m)? That mean the absorption coefficient(1/m) is the product of 100 times absorption coefficient (1/cm) from NASA-SP-3080?
Thank you in advance.
ljwbuaa is offline   Reply With Quote
Old   August 4, 2011, 02:45
Rami Ben-Zvi
Rami is on a distinguished road
That's right: an absorption coefficient of 1/cm, say, = 100/m. This can easily be understood, since the power absorbed crossing 100 cm is 100 larger than for 1cm.
Rami is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
User Defined Scalar (UDS) question (units) D FLUENT 0 March 1, 2006 20:04
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 09:25
Absorption coefficient for aluminium??? Thomas FLUENT 0 March 2, 2005 15:15
