how to implement periodic boundary conditions?
Old   May 19, 2005, 05:05
Default how to implement periodic boundary conditions?
kat
Hi
I would like to implement periodic boundary conditions to model open channel flow in an existing code which only has inflow and outflow BC. It's a finite volume code with a staggered grid. Time discretisation is by forward Euler. Solution through a Poisson eq for the pressure. How should I deal with this?
Katrien
Old   May 19, 2005, 05:55
Default Re: how to implement periodic boundary conditions?
Halim
Old   May 19, 2005, 05:57
Halim
I am using the periodic TDMA developed by Prof. Patankar. If you want to test it, please post here. I will give you that subroutine.
Good luck,
Old   May 23, 2005, 10:02
harry
I have the same problem.Halim, can you send me the corresponding code, thanks
Old   May 24, 2005, 03:47
kat
yes halim, I'm interested. thanks in advance!
Old   May 24, 2005, 06:27
Bobby
Hi, Halim, would you please also send me a copy of the code for periodic TDMA? Thanks a lot.
Old   May 25, 2005, 07:58
soufiane
I have the same problem. Halim, can you send me the corresponding code, thank you
Old   May 30, 2005, 09:25
Kristian Holmås
Old   June 16, 2005, 03:14
Daman
Hi Halim, I am also having similar problem. Can you please provide the TDMA solver by Patankar to me also?
Old   June 27, 2005, 05:28
ztdep
not the TDMA solver but Cylic TDMA solver.
Old   July 28, 2011, 16:15
behzad
behzadmaha is on a distinguished road
Originally Posted by Halim
;34565
Good luck,
I'm having the same problem, please send me the code.
behzadmaha is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Periodic boundary conditions in 3D Eulerian granular flow simulations dsm FLUENT 4 March 2, 2012 19:04
Problem with using periodic boundary conditions Sun FLUENT 0 January 14, 2011 09:47
Pitchwise periodic boundary conditions aqib Main CFD Forum 0 November 7, 2010 14:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
