Lax-Friedrichs flux
Old   July 30, 2011, 10:02
Default Lax-Friedrichs flux
aaaaaaaaaaaaaa
panou is on a distinguished road
Have anyone a paper which explain how lax-friedrich(approximate riemann solver) is derived?
Also if we suppose that (u+) is the values of a volume , (u-) the values of neighbour volumes and F the flux then the lax-friedrichs flux gives:
F=0.5*( (F+) + (F-) ) - a*( (u-) - (u+) )
This is applied by all faces of a initial volume regardless of its outward unit vector?
panou is offline   Reply With Quote
Old   July 30, 2011, 12:45
cfdnewbie
cfdnewbie is on a distinguished road
There's nothing too fancy about the LF-flux....its the average, penalized by the jump to add a strong dissipative constant.... not sure about the original paper, anybody has a hint???
you compute your F by the formula given above, and then do int (F*n) dx to take the normal into account...
hope this helps a bit!
cfdnewbie is offline   Reply With Quote
Old   July 30, 2011, 17:09
aaaaaaaaaaaaaa
Yes , sure. The third term is the dissipative term. Simply , i did not know if it has a complex theory under of it (due to appearance of eigenvectors as dissipative multiplier). With other words, i want to learn what assumptions do for to solve approximate the Riemann problem and finally result at this simply relation.
For other cases as HLLC or HLL there is a assumption on a number of waves. Here?
Old   July 31, 2011, 03:52
cfdnewbie
Hm, I'm only familiar with the LOCAL LF (also called Rusanov), where the a in your equation above is the local largest EV.... so that's your fastest wave...
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
Lax Friedrichs Flux Splitting srikant srinivasan Main CFD Forum 1 February 16, 2001 09:12
