Acoustic Pulse
Old   August 1, 2011, 11:47
Default Acoustic Pulse
kostas
pankos is on a distinguished road
I want to validate a Euler equations solver using the acoustic pulse as test case.
However, the exact solution of it, is complex to derived due to the appearence of integral which involves a bessel function.
What can i do for derive the exact solution? Any suggestions?
pankos is offline   Reply With Quote
Old   August 2, 2011, 03:23
cfdnewbie
cfdnewbie is on a distinguished road
would it have to be an acoustic pulse? you may start with sth simpler and build up from there to validate the code...e.g. the standard test case: pulse in rho..
cfdnewbie is offline   Reply With Quote
Old   August 2, 2011, 05:30
aaaaaaaaaaaaaa
panou is on a distinguished road
Could you tell me more information for this case? Some papers which setup the test?
The convection of isentropic vortex is not good problem for validation?
panou is offline   Reply With Quote
Old   August 2, 2011, 07:46
andy
andy_ is on a distinguished road
Integrate the Bessel function using one of the many tricks you learnt at school and university? If your recall is a bit wonky then googling "integrate Bessel function" is likely to provide a whole bunch of options.
andy_ is offline   Reply With Quote
Old   August 2, 2011, 12:23
cfdnewbie
Start by using a density pulse with a velocity field (should be convected along the streamlines).
If that works, use the method of the manufactured solution to create sth like a sinewave solution and test convergence with that - if you actually have access to the code and can add a source term, that is....
Old   August 5, 2011, 14:19
Default wolfram alpha
phillip
piljilaki is on a distinguished road
just ask wolframalpha.com to integrate it for you.
piljilaki is offline   Reply With Quote
Thread Tools
Trackbacks are On
Acoustic source term Nico FLUENT 1 October 11, 2012 02:35
Pathlines Single Pulse Mode in Fluent Matthew Roberts FLUENT 2 June 2, 2011 13:11
FLUENT 6.1.18 does have steady state acoustic mode Gavisiddayya FLUENT 0 October 8, 2007 11:24
Acoustic simulation Hugh FLUENT 0 October 1, 2006 21:54
Acoustic pressure larry Main CFD Forum 8 July 19, 2002 03:40
