Souce of noise
Old   May 5, 2005, 12:47
Default Souce of noise
kamesh
hello experts Does any one have experience in acoustics. I want to predict the sources of sound in closed duct (exhaust pipe)and i should also comsider the surrounding air.I tried to take mass flow rate as inlet B.C. I have modelled a small box outside the pipe and given a constant pressure. this B.C is phyical. I am using PISO algorithm. The problem is the rate of convergence of residual pressure is very very low.Any suggestions to improve convergence .Some suggestions on sources of sound are highly appreciable. regards kkreddy
Old   May 7, 2005, 20:44
Default Re: Souce of noise
harish
The easiest way to go about starting this problem is to use the linearised N-S eqn about mean flow and then using some implicit or explicit schemes to solve the problem. This would speed up the solution .I have found compact schemes or DRP to run pretty faster .
-H
Old   May 20, 2005, 11:55
kamesh
hi harish can u ellobate about compact schemes in brief.What is DRP.please explain in detail. thx..kamesh
Broadband noise problem Ric_85 FLUENT 0 September 28, 2010 18:42
Boundary Layer Noise Source Model Andrew FLUENT 0 January 12, 2009 22:47
Turbo noise macro Barri CFX 0 May 21, 2008 09:26
turbine noise naser FLUENT 0 December 3, 2004 13:37
Noise Heinz Wilkening Main CFD Forum 13 January 19, 2000 05:22
