October 26, 2010, 06:07 |
ENO / WENO scheme
C. Ziyad
Rep Power: 15 |
Hi all Would somebody could tell me how can I set up a procedure ENO / WENO end to increase the order of a Roe scheme. any helps are welcome ( code, docs, contact authors ... ) Thanks in advance
October 26, 2010, 08:50 |
Paper Referenc
Hi
You can refer the paper of Osher and shu where in they have described clearly how to proceed for weno schemes. You need solve the system of equations as in compact schemes to get the approximate values at the faces. |
October 26, 2010, 09:59 |
C. Ziyad
Rep Power: 15 |
Can you give me a link of this article ? have you used WENO in your works ? Thanks for you |
November 5, 2010, 03:11 |
Weno
Hans Bihs
Rep Power: 17 |
You can find information about how to use WENO in the following two books:
Shu C.W. (1999), High-Order ENO and WENO Schemes for Computational Fluid Dynamics, in "High-ORder MEthods for Computational Physics", Lecture Notes in Computational Science and Engineering Vol. 9, Springer. http://books.google.com/books?id=icd...tially&f=false Osher S., Fedkiw R. (2002), Level Set Methods and Dynamic Implicit Surfaces, Springer. http://books.google.com/books?id=SQQ...page&q&f=false |
November 5, 2010, 03:58 |
C. Ziyad
Rep Power: 15 |
Thank you so mush for your reply valgrinda and this links.
Unfortunately google does not show good part of his tenth book, in fact I just need to understand the principle of the method and the algorithm and after that will be easy because I have mastered my code perfectly. None of you has worked on the shallow water equations ? |
ENO scheme (ENO-Roe) (Shu and Osher). | J. K. | Main CFD Forum | 8 | March 28, 2013 08:09 |
Finite Volume WENO Scheme | DSS | Main CFD Forum | 3 | January 15, 2007 03:47 |
Flux splitting for WENO scheme | DSS | Main CFD Forum | 6 | January 10, 2007 10:59 |
ENO scheme asymmetry | vinod venugopalan | Main CFD Forum | 7 | October 7, 2004 11:21 |
ENO scheme asymmetry | Vinod Venugopalan | Main CFD Forum | 5 | July 22, 2004 13:06 |
