Setup of flat plate problem for laminar layer
Could someone to tell me what boundary conditions must be put at flat plate problem for laminar boundary layer?
I have solved the problem with below boundary conditions but i see a problem (incresment of density) at left lower corner at which connect the left boundary with symmetry plane. Left boundary: specify: pressure, all velocities upper boundary: same of left right boundary: all gradients are zero left lower (x<0): symmetry right lower (x>0): viscous wall |
sounds like you are overspecifying the lower left boundary, or you are having accuracy issues. a rise in density at that point means that you have created a stagnation point there, which is due to your flow coming from an Euler (symmetry wall) to a Navier Stokes (viscous) wall!
No, i do not refer at stagnation point at connection of symmetry and wall but at start of symmetry plane (at left lower corner of domain).
As i see , some information of domain arrive here and after increse the density except of reflection of information. |
Well, still, if you get a stagnation point (an unphysical one), you should check how the code sets the boundary conditions. Are they set twice at the point? Maybe there's a conflict, it sounds like you are over-constraining the flow there, e.g. what happens to the density in the symmetry BC routine? |
