car body aerodynamics
Old   June 10, 1999, 10:34
Default car body aerodynamics
Althea
I have been asked to do a CFD simulation of the flow over a car body. I have never done anything like that before and wondered if anyone has any hints and tips. It will probably have to be a 2D model as it is going to be fitted in around real work. I will use Fluent as it is available and I am familiar with it and I will probably use the k-e RNG turbulence model unless anyone advises against it. The requestee is interested in the velocity vectors over the body and downstream.
The simulation is more for interest than serious work although I would, of course, like to do a reasonably good job.
Thanks in advance for any ideas and the varied interesting and sometimes entertaining reading provided by users of this discussion forum.
Althea
Old   June 10, 1999, 15:55
Default Re: car body aerodynamics
D.Reynolds
I recall vaguely a hint from a conversation four years ago with a chap who was modelling a car body.
There was something to be wary of that had confused him (for a reason I don't recall). It was the fact that some car profiles he modelled had two stagnation points at the front end of the vehicle. The first generally located at the radiator region and the other near the bonnet/windscreen juncture. I guess the confusion could have involved his pressure plots and drag coeffient calculations in some way?
This may be of use to you, but if it turns out to be a fish (of the red herring variety) then discard immediately! Regards, Denver
Old   June 10, 1999, 17:44
John C. Chien
(1). You can use the geometry of a real car and find the symmetry plane profile. (2). Then you can run a 2-D solution over this symmetry plane profile. (3). A car is always 3-D, and a car model also is always 3-D. (4). It shouldn't be that difficult to model a rectangular block to simulate the flow over a truck. At least, it is possible to build a truck like a rectangular block. (5). But, a 2-D model car? That is if you use a 2-D CAD program. ( just a joke)
Old   June 15, 1999, 14:09
Eric Grald
Dear Althea,
I suggest that you work closely with your Fluent technical support engineer on this project, as we have people with a lot of experience in this area.
If you are not sure who your Fluent support engineer is, please send me your address and I will find out for you.
Eric Grald (ewg@fluent.com)
Car Aerodynamics avin_wind FLUENT 0 October 21, 2010 05:29
Drag plot on Car body m@rk@s FLUENT 0 May 13, 2008 14:53
External Flow Prediction around a Car Body S. Main CFD Forum 5 June 5, 2007 22:40
Car aerodynamics simulation (Pls help, urgent)! Wang FLUENT 1 February 23, 2007 16:06
Please help about car body aerodynamic analysis Tayfun Toraman FLUENT 2 November 30, 2004 08:52
