grid ressolution
Old   May 12, 2005, 04:53
Default grid ressolution
Kottam
Hello every body, i have some problem with my results. I did 3D DNS of the diffussion flame. in that i would like to know whether scalar dissipation rate is well ressolved or not? what is the test to verify it? i calculated Kolmogorov scale , ressolution is roughly comming around 12 times the kolmogorov scale.. but i would like to know is there any other way of checking of my results. thanykyou in advance
Old   May 12, 2005, 12:41
Default Re: grid ressolution
agg
You are calculating scalar dissipation rate. For scalars, the smallest length scale is the Batchelor scale. If Schmidt number, Sc=1, then the Batchelor scale is on the same order as Kolmogorov scale. For Sc>1, the Batchelor scale will be smaller than the Kolmogorov scale and can be approximated by the relation,
LB ~ Sc^(-0.5)*LK
LB = Batchelor scale Sc = Schmidt number = kinematic viscosity/molecular diffusivity LK = Kolmogorov scale
To resolve the scalar dissipation rate, you should be close to Batchelor scale and in case Sc > 1, a resolution of 12 times Kolmogorov scale will not be sufficient.
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 14:17
Taylor microscale with grid ressolution hanman Main CFD Forum 0 March 9, 2006 07:49
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
