Reverse flow
Old   May 13, 2005, 05:39
Default Reverse flow
P.R.Naren
How to tackle the reverse flow . what is the cause of reverse flow. the outlet is already set to pressure outlet so what else to be checked out. this is regarding simulation of two phase gas solid flow.
Old   May 13, 2005, 15:20
Default Re: Reverse flow
agg
Try to extend your boundary and see if flow still reverses. For one-phase flow, sometimes one uses a convective outflow boundary condition to avoid errors at boundary. You may want to check that (Ref: CFD by Ferziger and Peric)
Reverse Flow Bharati FLUENT 0 September 14, 2010 01:09
Flow simulation in reverse drum mixer Patel Chirag CFX 0 July 19, 2010 15:05
reverse flow alikami FLUENT 1 June 2, 2010 04:19
Reverse flow in the VOF model yan FLUENT 1 May 26, 2005 09:14
reverse flow Giovanni FLUENT 11 October 15, 2001 03:01
