You wrote: "when viscosity and delta T depend on type of streaming which in turn depend on mesh type" You have flow velocity u, in lattice units, which is limited, up to a value depending on the model. Then, you have a characteristic length L, so the only way to increase Reynolds number is to decrease the kinematic viscosity nu=(tau-1/2)*R*T*(delta T). With Delta T =1 fixed, decrease the relaxation time tau, which might lead to instability. What do you mean with "streaming which in turn depend on mesh type"? If you meant the stream step, it is supposed to be from one one to another, and that step is supposed to be fixed. If the boundary is located between nodes (due to the geometry your gas is inmersed) you use interpolation (there is a paper from the people from Exa) and it guarantees conservation laws. There are LB models relying on (around) Cartesian, Spherical, etc, but there is a price to pay when dealing with such non-Cartesian grid. Again, what is the point to use (general) polyhedrals when dealing with LB? |
As to why I want to work with LBM's with general polyhedrals is for the reasons that they represent the shape much better compared to the approach that involves cube. Another approach is the surfels that exa use to represent bodies.
PS: BY the way, are you working at X-Flow, Exa or? Just curious :) |
Thanks, I know that paper, and I have it. Thanks. The issue is that the use of FDS and/or FVM insert numerical dissipation, which is not desirable. Im aware of that many people are using so in LBM. I don't follow that path. On another matter: According to Exa, their constraints is Re < 10,000 SOURCE: http://exa.com/core-technology.html 1000 < Re < 10 000 can be reached for grid resolution far less than 10^3, as seen in fig 6 in this paper Mathematics and Computers in Simulation 84 (2012) 26–41 (http://www.sciencedirect.com/science...78475412001966). Interesting that paper compares two different LB models and they give similar results. However, no information if provided about their implementation in Exa or X-flow. So my main question are: 1-Is Exa using finite difference schemes, volume method, or in the implementation of the LBM? 2-What about X-flow? The only thing I know is that X-flow uses "MRT and refined-schemes". Beyond that, not sure about their implementations. Thanks in advance :) |
Thanks for the link. I am not well aware with x-flow but with PowerFlow i have fairly good idea. They are using single relaxation model, with the classical streaming ( fbar = f) so they are not using finite difference though it seems have published something separately (not in powerflow). I have some papers they published that outlines what they do. I can try to scan them into pdfs if you are really interested. They have this series of voxels of different sizes, typically ratio is 2 in length dimention. Number of solves vary on each size, so if coarse cell get N updates, finer children of it would get 2N updates (or delta T is half of coarser one). To join these fine and coarse cells they use liner interpolations. Currently their mesh is once generated then fixed during the iterations but they are looking into dynamic meshing and mesh movements (inferred from their job postings). Also about their limit of Re=10000, I think they are saying that uptil this Re they could run it without any turbulence model, after that if mesh is not fine enough they would need turbulence model. which actually should bail them out of stability issues too. My very personal opinion (which I can not verify or prove) is that Powerflow uses some kind of entropic update to keep the solver stable even on higher Reynolds numbers. Also I believe that speed of classic lattice boltzmann is main reason they are not using other LBMs, even though they are fully aware of developments of various other types of LBMs. (again this is an opinion).
I'm aware of the paper you are refering to by people of Exa.
But that construction is not local, unfortunatelly. If you are refering to Entropic LB (ELB) model, well, the paper Mathematics and Computers in Simulation 84 (2012) 26–41 (http://www.sciencedirect.com/science...78475412001966). shows that in 2D, the ELB is no better than the other one. There are other papers where 1D comparisons are made, and still the ELB is no better thatn the other one in 1D shocktube. Hence, there is no evidence that in 3D the ELB would be better, at least no independent people have tested anyway. These comparison are made by independent people, while the ELB creators still claim otherwise. There is an ongoing controversy seen on http://pre.aps.org/abstract/PRE/v84/i6/e068701, but that is another story. Maybe EXA is using positivity rule, to maintain positive populations, to avoid instabilities. Not sure. There is always a price, e.g. in the accuracy, since the issue is the boundary conditions, as shown in the aforementioned paper. There are hidding tricks at the boundaries, as usual. The question is: If PoweFlow is under/over predicting turbulent flows (according to some complains, never sure, but it what it is said in some forums) then: Is that due to their turbulent models? (It is well known than RANS can even given the wrong direction of the swirl, due to the modeling). What about the performance of PowerFlow and X-flow compared to other NS CFD codes? Are LB CFD codes faster? How faster? Two fold?, Three fold?, etc One thing is for sure: The car industry has NOT rejected the use of LB in CFD, as seen here: http://jobs.gm.com/job/Warren-Vehicl...48088/2687218/ Quote:
I mostly agree with your assesment about stablity. I do not have much opinion of it at the moment because though i have seen papers showing that it is stable and all , but I do not have first hand experience of it. By this I mean, like for example take starccm type solver, I have lots of experience with it and can say lots of things with confidence about its behaviour. But since I have never implemented entropic version myself and have not tried it on complicated cases, really can not conclude anything. Also about PowerFlow over predicting turbulence etc, it is really difficult thing to comment on, as it depends on lots of factors, their turbulence model being cardinal of them. About the performance, which is again tricky, for the same mesh sizes one it seems Powerflow would be faster than codes like fluent and starccm+ . It could be same speed or less efficient (not the word efficient, some solvers might take larger time step) than well implemented direct solvers based codes (that use FFT etc for pressure). On the other hand, one could run calculations with much smaller mesh sizes and also run steady runs to get results much faster than powerflow with say starccm+ . For transient problems related to external aerodynamics , it sounds most attractive.
Anybody has any experience with XFlow in FSI
nect to solid solver.... Trying to connect to solid solver.... ,what's mean ,searching for nastran solid.exe Quote:
Hello, Anybody has any experience with XFlow? Thanks,
Anybody has any experience with XFlow? Thanks, |
x flow wind turbine
hello everyone
i have one question can you help me that how can I set the rotor free to rotate due to the forces exerted by the wind? |
Hi Saket
MSC also owns scFlow, scTetra and scStream, which are pretty good CFD programs. How would you compare xFlow with say scFlow in terms of speed and accuracy? Thanks |
