k-epsilon source term
Old   May 13, 2005, 08:13
Default k-epsilon source term
max
Hi everybody I am working with k-epsilon model (density-variable version) to compute a simple jet in still air. My problem is that the convergence rate of the iterative solver of the linear system (Coniugate Gradient Method Stabilized) is very poor. I have already tried to improve it using a lower under-relaxation factor and/or CFL number but I have no improvements. I suppose the kind of the source term linearization for k and epsilon is not the best one. In particular the dilatation term is the one which destroy convergence rate. Have you some references where I can find some source term linearizations and/or critical discussion about them? Thanks MAX
Old   May 19, 2005, 13:53
Default Re: k-epsilon source term
tejus
USe tri diagnol matrix analysis (TDMA) to get your equations converge.it really workes. you can get the detail from the text book " Intoduction to finite difference methods" by Veerstag and Malashekara.
Old   May 20, 2005, 02:27
max
I am sorry, but I can not find this book. Can you check exactly the title and authors? I have another question: does this method work also for unstructure grids? I guess you can apply it only for structured problems. Nevertheless I will have look to your book, once I find it. Thanks
Old   May 20, 2005, 04:01
zxaar
i have been running k-e model on unstrcutred grids based on bicgstab and yes i also feel that convergence is very slow. for the same mesh fluent converges very fast, even though i make coarsening level to 0, (i am not sure whether fluent is using multigrids in that option too), but if i assume fluent uses gauss siedel only (when i make coarsening to zero), it is quite surprising that fluent solution conerges so fast. i will only come to know if i implement multigrids into my solver and this will take some time.
i am not sure what other people have experience with k-e using other solvers , for example FOAM (i guess) can work with biCGstab.
momentum source term zwdi FLUENT 14 June 27, 2017 15:40
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
