May 13, 2005, 08:13 |
k-epsilon source term
Hi everybody I am working with k-epsilon model (density-variable version) to compute a simple jet in still air. My problem is that the convergence rate of the iterative solver of the linear system (Coniugate Gradient Method Stabilized) is very poor. I have already tried to improve it using a lower under-relaxation factor and/or CFL number but I have no improvements. I suppose the kind of the source term linearization for k and epsilon is not the best one. In particular the dilatation term is the one which destroy convergence rate. Have you some references where I can find some source term linearizations and/or critical discussion about them? Thanks MAX
May 19, 2005, 13:53 |
Re: k-epsilon source term
USe tri diagnol matrix analysis (TDMA) to get your equations converge.it really workes. you can get the detail from the text book " Intoduction to finite difference methods" by Veerstag and Malashekara.
May 20, 2005, 02:27 |
I am sorry, but I can not find this book. Can you check exactly the title and authors? I have another question: does this method work also for unstructure grids? I guess you can apply it only for structured problems. Nevertheless I will have look to your book, once I find it. Thanks
May 20, 2005, 04:01 |
i have been running k-e model on unstrcutred grids based on bicgstab and yes i also feel that convergence is very slow. for the same mesh fluent converges very fast, even though i make coarsening level to 0, (i am not sure whether fluent is using multigrids in that option too), but if i assume fluent uses gauss siedel only (when i make coarsening to zero), it is quite surprising that fluent solution conerges so fast. i will only come to know if i implement multigrids into my solver and this will take some time.
i am not sure what other people have experience with k-e using other solvers , for example FOAM (i guess) can work with biCGstab. |
momentum source term | zwdi | FLUENT | 14 | June 27, 2017 15:40 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 13, 2000 23:03 |
