Physical meaning of Y+?
Old   May 19, 2005, 06:49
Default Physical meaning of Y+?
Wodo
Hi all, I try to figure out what's the physical meaning of Y+ from many explanation. But I still cannot get it! Can somebody explain for me, thanks!
Old   May 19, 2005, 18:35
Default Re: Physical meaning of Y+?
agg
Y+ is a non--dimensional parameter, based on which different regions near a wall boundary are divided. For example, a location of y+ = 5 will lie in the viscous region independent of the flow parameters (fluid, velocity, length of domain, etc.)
Old   May 19, 2005, 20:53
Wodo
Hi agg, thanks, Do you mean the Y+ is only an index to determine whether it is located inside the boundary layer or not? Then what's the Y+ range for boundary layer? thanks.
Old   May 19, 2005, 22:45
agg
To learn more about ranges, refer, "Computational mechanics and Heat tranfer" by Anderson, Tannehill and Pletcher.
Old   May 20, 2005, 01:27
Wodo
Thanks agg for your response.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Physical meaning of pressure in pressure eqn dontknow Main CFD Forum 2 August 30, 2010 10:12
Physical meaning of this velocity pressure correlation? huijingmm Main CFD Forum 0 January 22, 2010 00:20
Divergence of Tensor (physical meaning) John Main CFD Forum 1 May 22, 2008 15:48
The physical meaning of CO of outlet? ZHANG ZHIQIN Phoenics 1 December 3, 2002 23:30
