How to choose software for ventilation of a building |
August 30, 2011, 11:36 |
Didier
if I want to simulate the ventilation in a room or a building and I do not want to invest in expensive software, what software to use? most often the question arises whether the location of vents and size are correct. And also for heating. What is the proper way to start CFD without risk of being wrong by investing in software? For a room like this for example Didier :. France - Toulouse Last edited by Didier; August 30, 2011 at 12:08. |
August 30, 2011, 19:16 |
Hi Didier,
What is your definition of expensive software (i.e. where do you set the line between a cheap and an expensive software)? There are a number of established players: Phoenics, Airpack that are dedicated for these kinds of problems. There are also a number of new comers: blueAIR (from bluecape.com.pt), BlendMe (from ods-engineering), or Khamsin (this one is mine, but not ready for complex cases yet). The common thread of the new comers is to be dedicated to building industry and relying on openFOAM as a CFD solver. You may find that the tick is to appropriately represents the physics you are trying to model (air path, head loads, radiation, etc). Good luck. Julien
--- Julien de Charentenay |
August 31, 2011, 03:38 |
Didier
Thank you Julien for your answer,
in current applications of building engineering, the remuneration of an office is a few hundred euros for a house project and a few thousand for a small project (shop, a small public building, collective housing, industrial kitchen ..) I think a program that, in a room, would add a heater, wall heater, radiant floor heating, ventilation inlet, a ventilation outlet, a ventilation grill, windows, ... could cost from 200 to 500 euros. Then for your software, you could then progress by adding the consideration of losses in the walls, then the calculation with more complicated plans. By leaning on users, your software is progressing in the interests of your customers and you. |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 14:56 |
Solar Radiation in OpenFOAM | plainstyle | OpenFOAM Running, Solving & CFD | 15 | July 8, 2014 04:43 |
CFD software for natural ventilation of building & urban design | Christian Bosselmann | Main CFD Forum | 6 | April 1, 2011 03:00 |
New building machine for OpenFoam | gerbervdgraaf | OpenFOAM Installation | 23 | December 9, 2009 02:39 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
