les ..small doubt
Old   May 23, 2005, 02:54
Default les ..small doubt
student
i wish to convert my laminar code to les one, i have a small doubt, when i calculate mu_sgs, does it remain constant during the sub iterations of that time step, or do i calculate this quantity on each iteration.
Old   May 23, 2005, 04:34
Default Re: les ..small doubt
Nick
A mon avis, it depends on a model. If you use Smogarinsky's model, then in time step mu_sgs remains constant (it is obvious from it's form – gradients of velocities which are constant in each time step for the final iteration). If mu_sgs is inside the iteration process for a single time-step then it changes with iterations, asymptotically reaching the steady state in a single time-step. You can also try filters for small-scale wave perturbations (it's better than mu_sgs models) but here you'll have to use finite-difference schemes. Regards.
Old   May 23, 2005, 05:11
student
thanks Nick, this clears my doubt, i am trying to implement smogorinsky model only, and yes the gradients will remain constant during the time step and hence mu_sgs should also remain constant. thanks again.
doubt about DNS and LES of combustion chinthakindi Main CFD Forum 5 August 17, 2013 11:56
small doubt with fluent iņigo FLUENT 3 February 28, 2011 13:04
A small axisymmetric doubt, plz help ryan FLUENT 1 July 11, 2008 12:34
small test cases for LES on unstructured grids Fab Main CFD Forum 1 October 23, 2007 13:54
LES for Acoustics - A doubt Harish Main CFD Forum 11 May 11, 2006 10:11
