water hammer estimation
Old   September 7, 2011, 04:32
Smile water hammer estimation
Rajkumar
raju.kct is on a distinguished road
Hi friend,
Could you please tell me the approach to estimate the pressure rise in the system because of the water hammer effect?i've gone through some materials and mentioned that the equation ΔP=ρaV where ρ-density of liquid, a-Wave velocity (which includes pipe & liquid properties),V-Velocity of liquid flow at steady condition (i.e. before closing the valve) can be used, but for complex system i've some doubts in calculating impulse pressure, if the shock wave is propagating through a tube with lots of bends,will it affect the pressure raised during valve closure? And if two shock waves are coming in the opposite direction (when closing two valves together) and colliding at a point,is the pressure will be doubled at that point? or what will happen? As a beginner to this problem, i'm trying to understand the correct approach to calculate the pressure at least conservatively. Please correct me.
Thank you
raju.kct is offline   Reply With Quote
Old   September 7, 2011, 04:38
Rajkumar
water hammer
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
codes for water hammer on pipe flow park Main CFD Forum 0 September 28, 2008 01:43
How to simulate the water hammer pressure. arwang FLUENT 0 March 12, 2007 07:07
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
