-   -   Is Y+ depends on the tubulence model? (http://www.cfd-online.com/Forums/main/92266-y-depends-tubulence-model.html)
krishnag2002 September 8, 2011 07:23
If we use different turbulence models, the target Y+ will change accordingly?
cfd_newbie September 8, 2011 07:52
Does you question mean -
"If you use different turbulence models we should target different Y+ while making grids ?"
krishnag2002 September 8, 2011 09:18
Yes Thanks in Advance
cfd_newbie September 8, 2011 23:36
These 3 links might be useful -
http://www.cfd-online.com/Forums/mai...ga-models.html
http://www.cfd-online.com/Wiki/RANS-...bulence_models
http://www.kxcad.net/STAR-CCM/online...ulence-15.html
mettler September 9, 2011 08:26
yes, it does
for the turbulence model chosen, a preferable range of Y+ must be obtained to be considered valid the analysis. What drives this range will be the size of the first cell adiacent to the wall.
Far September 12, 2011 15:44
for example yplus 30 or greater for K epsilon based models and y+1 ~ for the SST, BSL and SA type models. It is the preferable approach.
although we can extend the K epsilon model to yplus = 1 range by using the special damping functions as implemented in the Fluent
similarly SST model can be used with the yplus = 30 mesh
P.S: Yplus = 30 or greater implies we are not solving the viscous sub-layer (yplus 2 or less) and buffer layer (in between 2 and 30). It is also called wall function approach
Yplus = 1 implies we are resolving the viscous sub layer. It is necessary to use the yplus = 1 type mesh if flow is dominated by the separation and reattachment where wall function ceases to be valid
In commercial CFD codes after Yplus = 11.06 wall function approach is activated and below this viscous sub layer approach is used
also check this link http://www.cfd-online.com/Forums/cfx...machinery.html
krishnag2002 September 13, 2011 02:06
thanks for your information. now I have some idea about Y+
