inlet/outlet boundary conditions for a forced flow in a channel
hi!
I'm trying to run a simulation about an internal flow in a converging channel, and i am in doubt about the boundary conditions to use: i do not have a fixed mass-flow rate since what i am investigating is the result of a volume force on the fluid flow (therefore i have a source term in the momentum equation...) this force should (and does) pump the fluid towards the narrower section (which is my "outlet") at which i imposed a 0 pressure - 0 stress boudary condition. At first i have imposed the same BC on the other channel edge since i thought the inflow should be free from stress and also at the same "external" pressure - being the motion triggered only by the volume force to which the fluid is exposed - but being my results quite different from what i expected i think something in my opinions is wrong... thanks for every hint anybody would give me ;) |
sorry for bumping.... ;)
davide_c,
It seems to me that applying a force to the fluid should yield a pressure gradient from the inlet to the outlet. By applying 0 pressure at both the inlet and the outlet are you not nullifying this gradient? Are you specifying total pressure or static pressure at the inlet and outlet? |
If i am correct, my pressure object represents static pressure (normalized by the density)
I spent some time thinking about it and realised the same conclusion about the pressure drop, so I switched the pressure condition on inlet to 0-gradient. Still, with this other arrangement i have problems -instabilities- after some time at the outlet. I am thinking about imposing a 0 gradient condition on the whole boundary - which I know phisically not having much sense together wit a no stress condition for U - just to try out... |
| All times are GMT -4. The time now is 03:59. |
