Help with flow past a vertical infinitely thin plate |
September 15, 2011, 05:02 |
TWB
Rep Power: 19 |
I need to simulate a flow past a vertical infinitely thin plate. One way to do it is to have a Cartesian grid, use a single column of cells to represent the wall. However, I am thinking of using a line to represent it instead. This is because it's supposed to be a very thin wall and I don't want to add thickness to the problem. I am using the fractional step which has the momentum and poisson equations. I have no problem specifying the BC for momentum but I am not sure about the poisson equation. If I use dp/dn=0 at the walls, my answer will just explode. How can I solve this problem? I've heard of using jump conditions but I can't find a paper which is suitable for my case. Can someone help? Thanks! |
September 16, 2011, 09:44 |
Jonas T. Holdeman, Jr.
Rep Power: 18 |
I assume you are talking about 2D horizontal flow past a vertical plate. I have done something like this using separate blocks on the left and right. This allows BCs on the left and right of the plate to be independent like the column of cells, but the plate has zero thickness.
However, I use a pressure-free momentum equation with Hermite finite elements, so your remark about dp/dn is not an issue. Come to think of it, the line option would work just as well. I have used something like the line option to model flow in a room from a (2D) ceiling fan where the fan was a flow-through line element instead of a barrier (flow controlled by the stream function difference along the fan). In this case there is a pressure jump somewhere. |
September 19, 2011, 05:43 |
TWB
Rep Power: 19 |
Thanks Jonas for the reply. I will look into it.
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Flow past 2 smooth circular cylinder | slip | FLUENT | 0 | July 8, 2010 18:45 |
Flow over a flat plate & Flow over a cylinder | cfdxue | Main CFD Forum | 0 | November 26, 2007 23:26 |
supersonic flow past flat plate | shuo | Main CFD Forum | 0 | July 28, 2007 19:47 |
Unsteady simulation of flow past wheel | Tom | FLUENT | 8 | January 18, 2006 10:54 |
