September 15, 2011, 17:28 |
radiation between solids in CFX
When modelling the heat removal by fluid I got problems in setting the proper radiation conditions/method. The model comprises two solid bodies separated by the vacuum. One body with volume heat generation is a radiation emitter with a certain emissivity of radiating surfaces. Another body is a radiation collector with the same (or different) emissivity of the surfaces and has a cooling channel with water circulating. The radiation heat exchange occurs between solids only. The question is how to simulate this radiation? I tried Monte Carlo method, surface-to-surface option with opaque boundaries and emissivity set to some value (0.8) As a result, the first body (emitter) reaches some equilibrium temperature, while the second does not receive any heat remaining at the initial temperature. Could anybody who faced similar problems clear up? I would appreciate! |
radiation in CFX | george | CFX | 28 | January 10, 2019 17:13 |
Importing solutions in CFX. | Alphonso | CFX | 1 | August 1, 2008 14:01 |
Solid to Solid Radiation | hossein | Main CFD Forum | 0 | April 17, 2008 09:32 |
Thermal radiation with solids rotating | luis | CFX | 0 | March 16, 2008 21:04 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
