K-ε model in ANSYS
I am trying to build a K-ε model in ANSYS to simulate turbulent air flow over two flat plates. Apparently I don't have a sound understanding of K-ε model, so when it required values of K and ε, I was a bit confused. How could I get these values? |
for example :
k= 1.5(U_average*I)^2 ε = C_u^0.75*(K/l)^1.5 |
take a look on turbulence modelling book by wilcox
Hi,shirley
You can calculate TurbK.E(K) and dissipation (ε) by K = 0.5*(u'^2+v'^2+w'^2) ε = (C_mu^0.75)*(K^1.5)/(Kappa*L) ; C_mu = 0.09 ,generally Kappa = 0.4 L = Lenght {u', v', w'} = turbulence intensity*free stream velocity For example, assume turbulence intensity = 2% free stream velocity = 6m/s Lenght = 5mm u' = v' = w' = 2%*6 = 0.12 K = 0.5*3*0.12 = 0.0216 ε = (0.09^0.75)*(0.0216^1.5)/(0.4*0.005) = 0.26 |
Hello shirley,
Based on theoretical aspects, Most of flow analysis will be considering in K-ε model because the flow at inlet of domain is considered as the fully developed flow. This topic related material will be easily available in Ansys help in the topic named as "Basic assumptions". |
