September 19, 2011, 06:04 |
Calculating Peclet no. for problem
TWB
Rep Power: 19 |
I need to calculate the Peclet no. to determine if an upwind scheme is better for my problem. The Peclet no. is defined as LU/D L = characteristic length, U = velocity, D the mass diffusion coefficient. I am simulating a flow past an airfoil in air. Is U the inflow velocity? L = airfoil length. What about the mass diffusion coefficient? I only managed to get from wiki: "Carbon dioxide in air has a diffusion coefficient of 16 mm2/s" Hope someone can help. Thanks! |
Calculating forces on a non-closed surface | ScottN | FLUENT | 0 | March 1, 2011 17:18 |
Problems in calculating the fluid traction on the current structure frame in 3D models | fw407 | OpenFOAM Running, Solving & CFD | 0 | August 6, 2008 12:04 |
Calculating time | thuy | FLUENT | 5 | April 10, 2008 04:23 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
A question about Peclet number | Zhong Lei | Main CFD Forum | 8 | March 12, 1999 08:26 |
