turbulent diffusivity
Old   June 3, 2005, 07:47
Default turbulent diffusivity
confused
why do we assume a constant turbulent diffusivity for all species in a reacting flow?
surely hydrogen is diffused more than, say, oxygen by tubulence. i.e. due to the fact it is lighter.
why dont we use a different turbulent Schmidt number for each species?
Old   June 3, 2005, 10:56
Default Re: turbulent diffusivity
ram
i dont know
Old   June 3, 2005, 11:10
agg
This is because turbulent diffusivity is not a preperty of a particular fluid, but that of the turbulent flow.
Old   June 3, 2005, 17:58
confused
hi agg,
ok. but still in reality would you not expect lighter species to be transported more than heavier ones by turbulence?
Old   June 4, 2005, 16:29
agg
That is true. Hence for example in LES dynamic models are used to account for the differences (if my understanding is correct). A constant is an approximation (and has worked) to simplify the model.
Turbulent eddy diffusivity for mixing?? Ray Main CFD Forum 3 November 5, 2020 11:57
How does FLUENT calculate turbulent mass diffusivity (m2/s) for the granular phase zhouwu FLUENT 0 August 6, 2011 04:51
What is UDS diffusivity of a self-defined material? aleisia FLUENT 0 March 5, 2011 22:08
Turbulent thermal diffusivity vitor OpenFOAM Running, Solving & CFD 2 August 22, 2010 15:43
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
