-   -   how to set inlet velocity of a 2d spouted bed? (http://www.cfd-online.com/Forums/main/93092-how-set-inlet-velocity-2d-spouted-bed.html)
jackzhan October 4, 2011 21:16
i've made a mistake,sorry
bageshwar October 5, 2011 05:56
description
Can u pls explain ur problem in detail?
to the current question try to determine the minimum fluidisation velocity and then determine the velocity of spout using some flow regime maps available in paper
http://www.sciencedirect.com/science...09250905000953
jackzhan October 6, 2011 02:38
thank you bageshwar, i've solved my problem.
it was that a cylindrical/conical based cylindrical spouted bed should not be simulated by a 2d-plan model , it should be simulated by a 2-d axial asymmetric model , assuring that the inlet velocity and the superficial gas velocity are in accordance with the experiment results.
mohsen0488 October 7, 2013 10:12
hi
i have a problem,i want to modeling hydrodynamic of spouted bed my experimental reference is HE et al .
diameter of inlet=19mm
solid density=2500kg/m3
diameter of solid=1.41 mm
inlet velocity=41 m/s
H0=325mm
H=1000mm
initial volume fraction of solid=0.588
drag model= Gidaspow
geometry is 2-d axial asymmetric
other Authors reach spouting, in my simulation I cannot get any spouting.
can you help me?
thank you in advance
