June 14, 2005, 01:55 |
Start of averaging in LES
I am doing a LES for a surface mounted cube inside a channel and would like to know how I determine the starting point of averaging my results. Right now, I take a look at the drag coefficient and if it looks pretty 'turbulent' I would start averaging; but shouldn't be there a more mathematical way to determine the start point? Regards! fab |
June 14, 2005, 07:03 |
Re: Start of averaging in LES
One way is to low pass the unsteady drag coefficient signal. If the filtered data are (almost) steady or periodic, you probably can initiate the averaging process. Another possibility is to start immediately the process but then split your averaged data into several files of equal duration. At the end of the runs, you will be able to compare the first order statistics coming from each files to see if the earlier files differ from the latter ones. The averaging over all the files whose statistics closely match the last ones should result in converged first and second order statistical data. Hope this helps, Lionel |
June 16, 2005, 04:53 |
Hi Lionel,
thanks! Regards fab |
Starting field averaging using libFunctionObject after certain time | eelcovv | OpenFOAM Programming & Development | 25 | December 7, 2015 22:28 |
OpenFOAM LES: Averaging Velcoity | Ollie | OpenFOAM | 2 | April 20, 2011 07:05 |
averaging in les | klilla | OpenFOAM | 2 | February 10, 2010 02:29 |
Averaging LES | iko | FLUENT | 3 | July 3, 2008 05:55 |
Averaging Method for LES | Kim | Main CFD Forum | 0 | November 21, 2001 07:18 |
