-   -   Surface y+ manual calculation (http://www.cfd-online.com/Forums/main/93303-surface-y-manual-calculation.html)
Yur October 11, 2011 08:56
Surface y+ problem
Hi guys,
I need toget the surface y+ results for internal flow. I have the following equation now, but it's not showing me the correct values. Could somebody give me a solution for this.
surface_yplus = (y_velocity*cell_size)/char_viscosity;
The y_velocity is the downstream velocity direction. The cell_size is different for each region in the geometry and the char_viscosity is just a constant.
ps. It's a low speed simulation (0.75 m/s)
Thanks in advance.
bluebase October 23, 2011 12:53
Hi Yur,
may be it's late:
Check your formula again and compare with http://www.cfd-online.com/Wiki/Dimen...e_%28y_plus%29
u_star is not the downstream velocity.
When you follow the link for friction velocity one gets:
u_star = sqrt( tau_w / rho )
Follow the link for wall shear stress to get a formula to compute tau_w.
I hope this is helpful.
Sebastian.
