Analysis of two fluid cross flow heat exchanger. |
April 17, 2016, 03:52 |
I am supposed to do an analysis of two fluid cross flow plate fin type heat exchanger for my college project. The heat exchanger is insulated from the surroundings. The heat exchanger is investigated for step perturbations provided in hot fluid inlet temperature. The corresponding response at the outlet of cold fluid is studied. Can anyone tell me what software should I use for the analysis and post me a tutorial to understand the process? Thanks |
April 17, 2016, 07:20 |
#2 | |
zeshan
Rep Power: 9 |
December 3, 2017, 12:39 |
#3 | |
Francisco Angel
Rep Power: 13 |
See the image on this link: https://drive.google.com/open?id=15v...j78wsOILVT9hUB |
December 3, 2017, 13:30 |
msh in gmsh
Leonardo
how can I make a duplicate mesh in the structure and not duplicate in the fluid in the GMSH?
Geometry is the cross section of the guitar, I'm having trouble putting just fluid in the sound hole of the guitar. and I need the mesh to be triangular regular between point(4) and point (5), it's the sound hole, and there I need it to be just fluid and the line(4) disappears. help me please, i'm beginner of scientific research msh code .geo dim = 34; gridsize = dim/4; dim2 = 38.3; gridsize2 = dim2/4; dim3 = 48; gridsize3 = dim3/4; Point(1) = {0, 0, 0, gridsize}; Point(2) = {dim3 , 0, 0, gridsize3}; Point(3) = {dim3 , 10.5, 0, gridsize3}; Point(4) = {dim2, 10.5, 0, gridsize2}; Point(5) = {dim, 10.5, 0, gridsize}; Point(6) = {0, 10.5, 0, gridsize2}; //+ Line(1) = {1, 2}; //+ Line(2) = {2, 3}; //+ Line(3) = {3, 4}; //+ Line(4) = {4, 5}; //+ Line(5) = {5, 6}; //+ Line(6) = {6, 1}; //+ Line Loop(1) = {6, 1, 2, 3, 4, 5}; //+ Plane Surface(1) = {1}; |
heat exchanger, heat exchanger two fluids |
Display Modes | |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
heat exchanger analysis | durgesh pal | Main CFD Forum | 2 | January 29, 2015 06:03 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Simulation of Helical Heat Exchanger in CFX : Fluid Flow Software | topper611 | CFX | 1 | March 19, 2013 05:49 |
