32-bit to 64-bit
Old   June 17, 2005, 18:04
Default 32-bit to 64-bit
Khurram
I want to convert my code from 32-bit machine to 64-bit machine. The code is written in Fortran. Everytihing is working fine but when i want to change the memory size beyond 3-bit machine, I have a problem.
The problem boils down to following:
Integer*8 max Parameter (max=8.e9)!here is a problem common m(max)
This is giving me an error. Basically I have isolated the problem to finding a way to define double precision integer with parameter command
I would appreciate any feedback
Old   June 20, 2005, 04:05
Default Re: 32-bit to 64-bit
andy
You parameter statement is using a real literal instead of an integer literal. This will give a compilation error. You must use an integer literal (i.e. 89000000).
Thread Tools
Trackbacks are On
Saved in Workbench 32 bit, open in Workbench 64 bit. Black Ni ANSYS 2 July 28, 2011 09:32
Issue with running in parallel on multiple nodes daveatstyacht OpenFOAM 7 August 31, 2010 17:16
64 Bit software or 64 bit compatibility? EphemeralMemory ANSYS 1 August 31, 2010 05:29
UDF problem/32 bit vs. 64 bit RE13 FLUENT 2 February 25, 2008 12:31
LinuxAMD64 version of java is actually 32 bit foret37 OpenFOAM Bugs 1 October 19, 2007 03:26
