October 23, 2011, 09:49 |
Low Reynolds Airfoil Modeling In Fluent
Morteza
Rep Power: 15 |
Hi. I am modeling anderson Spica airfoil in fluent.
the maximum velocity is 40m/s. the Grid is CH what is the best boundary condition for inlet outlet and upper and lower boundary. which solver can predict the cl and cd more accurate. what about under-relaxation factors? discretization methods and pressure velocity coupling? I did not get good result by my own settings. the residuals remain in high value. and cl and cd oscillate. |
October 24, 2011, 06:03 |
FlowLy
Rep Power: 15 |
I would put Pressure Far Field for all the boundaries.
kw-SST usually is the most accurate; but for airfoil you can use Spalart-Allmaras, is computationally cheaper than kw-SST and was developed especially for this application. Under-relax factors: keep the default; if you have problem with convergence it can help if you lower them. But usually, if it does not converge, there must be a problem either in the formulation of the problem (BC) or in the mesh, or in the geometry.. Hope this help cheers |
October 31, 2011, 12:46 |
Morteza
Rep Power: 15 |
Thank you so much dear Guili
November 23, 2011, 04:40 |
Rep Power: 16 |
You have to watch out for transition, as none of the RANS models accurately captures it. Therefore your Cd maybe higher than results obtained in the literature. XFOIL should also help.
Low Reynolds Modeling Lam Bremhorst | Mo-ITB | OpenFOAM Running, Solving & CFD | 3 | November 17, 2017 11:07 |
Low Reynolds Modeling | Mo-ITB | OpenFOAM Running, Solving & CFD | 0 | June 16, 2010 03:10 |
Flapping Airfoil Simulation in Low Reynolds Number Flow | M.Sc_Student | Main CFD Forum | 0 | April 6, 2010 09:30 |
Fluent 12.0, Low Reynolds Number Flows | anandvksin2003 | FLUENT | 1 | January 26, 2010 05:16 |
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) | Josh | CFX | 9 | August 18, 2009 11:31 |
